I am pretty sure the LTE's make the most power. Search the topic you will find this info without a doubt. DMC duals would probably be next. I am in the same boat as you with a single exhaust thinking about switching to duals. But everyone says if you keep your money, have it ported and polished, high compression piston, and cam - you'd be fine. This is the route I will probably take.
