Are you honing it for any reason? If you bore or hone it you will need to get the cylinder re lined.
its an 07 which has never been touched inside... so i was assuming/suggested by the shop im taking it too that it will most likely need something, atleast a hone!
by re lined you mean re chrome plated?? if thats what its lined with!!??
The stock cylinder has a nikasil coating in it. As Bo stated above you dont hone a coated cylinder the same as one with a sleeve in it. Make sure your builder knows what he is doing so that it is done right.
