well i want to get a wiseco 11-0-1 piston and a new cam and im not sure what else i would need? i was wondering if i get a 11-0-1 piston do i need a new stroker crankshaft. and also with the piston do u think its worth it to go stage 2 cam and the extra 150 for spring + installation or should i just get the stage 1 cam, i really dont want to spend the extra money on springs, but is there a major difference between them worth spending the extra money for the spings and going with the stage 2.
What are you planning to do with this bike? That along with budget will determine what you build.
You don't need a new rod or a new crankshaft for that matter.
i would go with the stage 2 sense the piston will comp for the powere the stage one will give in low end
