Hi there,can anyone tell me the best route to take.I need a new piston and have been advised to get a 11:1.What make should i get and where is the best place to get it from.The piston i have at the moment says 100 on the top of it,is this a standard one and what size is the next one up.Also someone told me i might not be able to rebore my barrel coz of the metal its made of can some one please shed some light on this thanks julian.
2004 660 raptor.:)
You can bore a 660 cylinder. Wiseco is a good piston in the 11:1 CR. The next strp for you would probably be a 101mm. Then that leaves room for a 102mm later on. Don't know the best place to buy them. Ebay or one of the site Sponsors could get one I'm sure.
Thats the one you want there. A cometic gasket kit is also a good kit for the 660. If you get the full gasket kit for like 63 it will have your clutch cove a side cover gaskets to. Always nice to have on hand and not much more for the full kit.
Thats a good piston, Im running it now but I have the 102mm.
Good luck..
