1 - 2 of 2 Posts
So last week my raptor decided to shear off the one way bearing bolts and throw them thru the stator case. I've got a new case bearing and flywheel comming in the mail. Only issue is the stator rotor assembly was slightly damaged by the bolt. The bolt left some slight grooves I'm the rotor assembly and flattened one spot in the raised section of it. I can't for the life of me find another one so 2 questions
1 can I just clean up the burrs and run the assembly I have with out issue.
2 is there any where I can buy a new assembly
Stator's are readily available (try Ricky Stator) .. picture of damage would help.
1 - 2 of 2 Posts
