1 - 11 of 11 Posts
I used a 220 and a 320 grit 3m standing sponge. Put a floor jack under the rear end. Take the tires off. Fire it up and put it in second gear. Be carefull not to get your fingers in the chain. It will take the gold color off and look like chrome. You will probably need to go over it with some 400 and 800 grit sand paper too. Make sure you use water and wet sand.
1 - 11 of 11 Posts
