when I hook the computer to the bike, the numbers on the tps% vary from 0 to about 5 is this normal or should it be stuck at 0 until the throttle is pushed? I have reset the throttle range several times and it still varies? Any ideas? :3question:
Ever use the "Set Throttle Position" feature?
I didn't rev her up but, is there any chance in stock form I'm not getting full throttle out if her?
yes you might not get full throttle based on the position of your screw in the throttle case on your handle bars
