1 - 20 of 24 Posts
I recently bought full FMF exhaust and pcv and took off air box lid. Installed everything and now my 2008 700 raptor wont even start but if i take to pcv out its starts and runs fine. I have an error code 2303 vr module unsynced. has anyone herd of this i cant figure it out ive spent hours on the laptop trying different maps and updates nothing is working please help if anyone knows what to do or have had this problem
GARAGE CULTURE
There are two of the connectors that are exactly the same. You might have them switched around. Think the one goes on your tps. Worth a try.
Sent from my GT-P7500 using Tapatalk 2
Discussion Starter #3
ya tps should be on the right side in throttle body i checked that pretty sure i have the right plug thanks for the reply i will check again
Glad to see you here Myles, with the combined thoughts on this site, we should have you going in no time.
Power commander themselves have a pretty good customer service as well. It wouldn't hurt to try giving them a call also
www.gtpoffroad.com
seems easy but make sure the ground is good on the PCV.
Does the PCV give an error or is it the bike??
www.gtpoffroad.com
I think Dynojet is your best bet on that. They are pretty helpful. I haven't seen that error before.
Ever contact Powercommander themselves on this Myles?
As said, make sure the ground is good, and using the correct connector. Both are in the same area and look identical. Don't hesitate to call Dyno Jet/Power Commander, they have great tech support. Call early, as they get busy.
Welcome to the forum.
Around 6:40 I think.
Discussion Starter #14
i did talk to them it was the pcv itself so they sent me a new one and im back running again thanks everyone for the input. they only problem now is my quad doesnt seem to be running that great. is there a way to get other maps other then ones one the website
I'm glad you got it figured out. I'm sure they warrantied it for you. Did you talk to Jerry?
The maps on the web are usually good for the big 3. If you have more mods then the map will be more complicated. I would call Curevo for a better map. His advice may be free, but it's nice to spend some money at the same time.
What are your mods?
That is fantastic Myles.! I told you hopping over here we could line you up and get the bike running right. Now it's just a matter of getting your tune right.
Discussion Starter #17
yes it was warranty talked to a guy named Michael. bike just backfires real bad on decel so i need to figure out some programming for it
Depending on where you bought the origional, it may not have been mapped? The new one would come with the same map as the old one. I would start from scratch and load a new map.
Discussion Starter #19
i got it all programmed ran then died same code on the pcv came up now they want me to send this one back. its getting a little ridiculous is there another fuel controller anyone would recommend? i have full FMF exhaust
You can get a MSD Blaster. I know that Curevo and TQS sell them. But I've heard they have trouble to. There is less support for mapping, but eisier to map (I've heard). Yours is the first I've heard of for a looong time.
Last year I had a PC5 that had a intermittent wIre. It was 13 months old, I bought used and they warrantied it, no charge.
1 - 20 of 24 Posts
