1 - 20 of 24 Posts
Anyone using one of these? And are you installing it to your stem? I feed like i need some type of bushing for them to work?.
I have one. It installs onto a plate that bolts directly to the stem. The plate allows you to move the bars about an inch forward or back.
Discussion Starter #3
Mine didnt come with a plate. It came with a lonestar stem but i seems like i am missing some bushings.
The stock steering stem will come with a plate for the actual mount. If you have an aftermarket stem like a Lonestar you will not receive a mounting plate. However, there should be a support bracket "plate" that goes between both clamps on the front side. This keeps them from rotating. The shock and vibe clamp for the aftermarket stem installs just like an anti vibe clamp. If you are missing the bushings and washers you need to contact whoever you bought the stem from.
Discussion Starter #6
yes i have that plate but i am unable to use that plate b/c the stem mounting holes are too narrow. Placing the clamp to close together. Even if i was able to use that plate it still wouldn't solve my problem of mounting a 1/2 bolt to a 1" hole. The only thing i can think of is that i need four conical bushings like how other clamps for anti vibe stems attach.
That's not where the plate goes... Let me see if i can find a picture of mine, hang tight.
Yes, you need those conical bushings and washers.
Discussion Starter #10
I can't find pictures of mine, but here is something i found on google. The black plate is the one that holds both the clamps together, the clamps go straight into the steering stem.
yes my clampes are too close together to mount the plate like that.
Discussion Starter #11
i am getting a package from lone star tomorrow i hope those are the bushings/ washer and sleeves i need and not the just the bushings i ordered.
Discussion Starter #14
The plate doesn't work with the stem they sent me.
Sounds like you have an anti vibe stem.
yup lonestar, i might be receiving the bushing today. I dont know why they would send the stem and bushing apart. I bought the stem and clamps as a kit from atv galaxy. They ready didn't send me track for anything except one part. If wasn't that i get notifications the day before. I wouldn't have know stuff was about to get here.
I believe there should be a crossbar that ties the two clamps together in your kit when you get it as well. That is not needed on stock stems as the plate holds them together.
Discussion Starter #16
the plate does not work for me b.c the clamps are to close together
1 - 20 of 24 Posts
