Hi
I was checking my preload adjustments and I think they are messed up.
My bike is a 2011 model.
I measured the shock spring from the bottom plate to the bottom of the adjusting nut. Is this the correct way?
If it is my settings from the stealership are wrong and are way out of spec.
I am only using this as a starting point i weigh spot on 160lbs so I was using the owners manual as a reference and it seems the measurements are all messed up.
Thanks is advance for any help
hey cheers frenchi.
But I would still like to know where to take the measurement from on the shock because after I make the adjustments I still want to know if I am in spec for the stock spring.
If the sag is set correct and I am not with in the min/max specs for the stock springs I will have to get them changed.
