the other day i was doing wheelies(w/ my new 15t awsome) when i noticed a strong gas smell. i actually stalled it one time and head what i thouth was a timing chain slap. when i started it back up thats when i smelled gas. looked around and found the oil resivor full of thin oil that smelled like fuel. i started panicing thinking i had blown a ring or somthing. got looking through the service manual and found that if i still had compression than it couldnt be a ring. wondering if mabey from doing long wheelies somehow starved the oil pump of oil causing it to loose prime. this would explain the abundence or oil in the tank, i let it sit and checked it the next day still full so i pulled some to put in a bottle to let it seperate. all oil no gas. so i started it, let run for a few and checked it again, now its ok?? i think it re-primed itself. anyone ever loosen that bolt on top of the res. to check oil pressure? am i way off here of what?? thanks SMIB
