1 - 20 of 42 Posts
ok so i did search a lot and nothing came up, my problem is thatinstalling the sensor on the inner plastic guard is weak in my opinion, and the c clamp is fine, but when installed behind the guard, the bolts will hit the rotor.
the magnet is just fine in the rotor bolt but the sensor is giving me a hard time.
in the pics you can see how the bolts that hold the rock guard and c clamp will not clear the brake disc, the sensor that goes in the clamp does not hace a problem but the one on the spindle wont clear the rock guard either.
I had to drill out the section of the rock guard to make it fit right. I think I understand what you're saying now. If you drill/cut out the section of guard where the sensor picks up it should then sit flush again.
Can you remove the hub and take a pic of the spindle straight on? I dont remember the rock guard being what holds on the clamp. I want to say the clamp uses 2 different holes but without seeing a pic of it its hard to say for sure.
I called Dale since he is at home so he can snap a pic of his installed, but I think he removed the rock guard all together. Sorry man, I'm still at work. Nothing looks wrong that I can see, but I'm sure I'm missing something.
1 - 20 of 42 Posts
