1 - 16 of 16 Posts
Will you get the same reading on a car dyno as you would on a quad/motorcycle dyno? I'm going to dyno my truck and they guy says it works on any thing from like a 1000HP down to 5HP.
Well I wanted to see where I am before the motor work that I'm going to have done.
I'll post it up next weekend right now its the dmc force 4s, pc3, pro design, and a dyno tech fs. HDD is going to do a trail set up in march with the hc3 he said it will be more reliable than a billet cam, the +3 tb, I guess a mild porting and a 11.5:1 piston. The guy at HDD said it would it would be about 65 HP when its all done. I want something that will beat ky cousins trx but still reliable so I don't have to keep adjusting it.
I put my Suzuki LTR and Raptor on a atv dyno and then on our dyno at work and the dyno at work read 1 hp lower then the atv one but that doesn't mean anything. So I also say car dynos will work great. hardest part was strapping it down.
2011 RF Fantasy FootBall Champ
Tell me about it. 9 straps and still blow the tires off the dyno.
Bitter sweet.
where do you guys find all these dynos? my neighbour has an engine dyno but he can hook a chain driven motor up to it just his turbo RX1 and car engines
Google it Tommy, You'll be surprised to see how many dyno's are around. I found 12 ATV dyno's within a 100 mile's of my house.. One of em is right down the road..:)
I know our car DynoJet is with in a few hp of a bike DynoJet. I find what tires you use can really very the #. I like the car dyno better my self if you are much past 60hp.
what kind of tire should I use? I have kenda kutters on there. I don't have street or drag tires but I can get a par of worn down tires so the tread isn't to thick.
Cool.
I use 22in Duro tires. I run the same tire on ever bike so the ## are comparable. Much more the 50hp through dirt tires you really start to lose traction.
Discussion Starter · #16 ·
Cool.
Ok thanks, what about worn down dirt tires would they keep the traction better? HDD was saying I should be around 62-63+- a little when I get the work done.
1 - 16 of 16 Posts
