1 - 11 of 11 Posts
2006 Yamaha raptor 700
Has anyone or is anyone running this Quantum fuel pump in their raptors? If so, how well does it hold up and does the low fuel sending unit work? I've posted a picture below. The fuel pump I have is trashed. When I pulled it from the tank at least 3 of the 4 wires were broken. Tried to repair it but could not find the clips that slide into the factory plugs. Not really wanting to spend 500 on the OEM but if that is my only option then I will.
Line Font Output device Rectangle Gadget
Administrator
Whats the cost on those vs OEM? All of your factory wiring is good, just the ones on your damaged fuel pump were bad then?
This one is 179 vs 500 for the OEM. I'm guessing the wires on the old fuel pump are the only thing. I tried wiring the pump to a battery but did not hear it start up.
I replaced my pump with a Quantum "kit". It came with the pump, wires, and filter. Haven't had any issues with it at all. Sounds like your fuel level sending unit and all is shot? I can't speak on the quality of the entire assembly that you have pictured but like I said I haven't had any issues with my Quantum pump...
I run them and have them as spares, never a problem. I just buy the pumps, unless there is a problem with your assembly there is no need to replace anything else.
Does quantum/QFS sell the entire assembly?
Is it a pain changing ONLY the motor? I thought the wires off motor would be a bitch squeezing back in there?
1 - 11 of 11 Posts
