doy you guys adjust the max speed bolt on the throttle? Is it ok to take it all the way out? :3question:
Discussion Starter · #2 ·
some one please just give me a quick answer.
That really doesn't have anything to do with top speed unless its screwed in alot. Just unscrew it so that the thumb stop on the inside doesnt hit it.
VIP AKA Corn Dog
It's a limiter, you don't need to have it adjusted in like a Banshee unless you want to regulate the max throttle, if a younger or less responsible person is going to ride it. Stock, it comes all the way out. It may have been put on there only because they use the same part for the YFZ450, which has a carburator, and carbs have to have a max so the spring on the slide won't bind.
