Hey guys I am a newbie here and I just got a raptor and my question is. That after I let my atv start up and run for. A bit when I put it into first it dies everytime unless I rev it up a little bit before I put it in gear. Is that how I am suppose to do it or what is wrong and how so I fix it. it is a 05 yamaha raptor 660
turn you idle screw up,it is located on the left side of the bike look like a triangle and is brass in color
How many turns do I need to turn it and would the idle be the problem? Because if I don't get it gas and just try to put it in gear for the first time it dies but after I get it in gear after giving it a little gas and it doesn't die then I don't have to do it at all again, it just goes in gear and stays running
Does it Idle when in Neutral ?
Your problem is normal, as long as it goes away when the engine warms up, idle speed should be around 1600 to 1800 rpm............
Let the engine warm up longer.
