so with all the other problems started the tear down to clean the carbs ......and i find a pin hole in the radiator where the head light was rubbing on the edge of the rad can this be soldered or will i need to spring for a new one.......just one more problem to add to the list lol:confused:
If it is just a pinhole, clean the area around it well and use a spot of JB Weld.
ya thank you that is what i did
If the JB fails, go to NAPA and buy hot melt designed for rads. This stuff works great on core tubes also when they get hit by small rocks. It looks and feels just like those hot melt sticks, but a bit smaller in diameter. It's applied using a propane torch.
Dan
maybe ill try that if it fails im in a little town 1200 ppl down here and 150 miles to a decent auto store
