Well, the Mishimoto radiator, which is advertised fitting through 2012, will not work with the 2015-2020 fan without modification.
The Spal fan I have bolts right up to the stock radiator too.
The overflow tubes are also the same I.D and O.D as the hoses.
The tube off the filler neck threads in, and it's wall thickness is pretty stout, so it can go in the lathe and be turned down.
The other is tig welded on, so will be a pain.
The rear of the Mishimoto is also not flat, as the outer frame is higher, and even though the Spal fan squeezes in, it's going to make mounting a little more challenging.
I need to give it some thought, but as of now, a simple cross bar to the threaded holes, using 2 instead of 3 may work.
My Dad is a retired engineer, so I'll get his thoughts tomorrow on the best way to mount the fan.
Always fun when the part isn't specific to the application, but it's worth the effort for better cooling.
