1 - 15 of 15 Posts
Ok guys so I bought it 3 months ago so and my friends say that it blows a little bit of blue smoke when I let it the throttle in 6 gear. Is that true, because I had it for 3 months and ever time I check the oil it’s the same level
Check the spark plug for oil fouling, it would look wet, but i think its such a small amount of oil you wouldn’t see the difference, you could also do a compression test just to rule out the rings, or it could be valve stem seals
Is it beat up can you tell it has hours and hours? Sounds like a new piston in rings in the near future. I would not ride alone in long trips with that quad. Could leave u stranded and then the boogeyman and crooked hillary will scare you from the trees in the trails.
This is great lol
Discussion Starter #11
Yeah it didn’t really smoke a lot. And my plug and my coil didn’t have any oil stuff on it also I think I’m going to try a oil change and new oil and maybe valve covers
1 - 15 of 15 Posts
