1 - 2 of 2 Posts
Based on your description and photo you are referring to the adjustment screws which are components of the rear axle bearing carrier. If your carrier and the bearings are still good and you just need bolts, you may be able to reproduce them at a hardware store or dig through the parts microfiche on an OEM distributor/dealer's website to find the part numbers and order them. It may be a good idea to check the carrier and bearings though too.
1 - 2 of 2 Posts
