21 - 40 of 44 Posts
Discussion Starter #21
Raptor 350 Headlight/Headlamp Bulb Information from Yamaha Owners and Service Manual
Refer to prior post in this thread for more details on headlight bulbs. This is just a quick note.
Man. NO place carries H6 headlight bulbs. It seems they are very specialized bulbs. May have to modify another style bulb by taking off the mounting ring. But then there's the odd back two connectors that are elongated. I would like to upgrade the front headlight bulbs to a low energy high output LED cluster bulb. I would like to reduce running power requirements so the battery gets the full stator energy as I like running with headlights ON during the day.
Discussion Starter #22 (Edited)
Raptor 350 Model Number and Warrior Model Number and Model Number Variants from Yamaha Owners and Service Manual
Here's a general overview of understanding Yamaha Raptor 350 model numbers and Warrior since the Raptor 350 TOOK over the Warrior 350 and many of the parts are the same (drivetrain not plastics) and the Warrior service manual is used on the Raptor 350.
1987 - 2004 Warrior 350 model = YFM350X (X=Warrior)
2005 - 2013 Raptor 350 model = YFM350RXR(C) (R=Raptor?)
2005 - 2013 Raptor 350 model = YFM350S?
2005 - 2013 Raptor 350 model = YFM350XP?
2005 - 2013 Raptor 350 model = YFM350XJ?
Warrior and Raptor History (why is this important, heck I dont know but heeere we go!)
When it was first produced, the Yamaha 350 Warrior set the bar for all-terrain vehicles (ATVs). The Warrior ATV was in production for 17 years and received praise for its efficient, fun and user-friendly design. In 1987, Yamaha introduced the 350 Warrior. In 2004, that model was discontinued, and Yamaha introduced the 350 Raptor ATV in 2005 in order to improve the sport performance of the line.
The Warrior was equipped for strong, midrange pulling capabilities and was fitted with a snorkel to allow it to travel through water and mud. Its basic design, however, stayed relatively untouched: a six-speed transmission with a 350 cc, four-stroke engine, hydraulic disc brakes and long travel suspension.
In 1987, when the Warrior was introduced, it was the first-ever electric-start ATV. Over the years, the Warrior developed a cultlike following as it became the world's all-time top-selling sport ATV.
2004 was the last year Warrior 350 and 2005 was the first year Raptor 350. Plastics from the Warrior changed to the Raptor for a more sport look and the drivetrain stayed mostly the same. This is an important note to remember.
ATTACHED are images. First is the model number I mentioned before being one of many listed for Raptor 350s. Note the XR(C) at the end. Second pic is the WARRIOR -SERVICE MANUAL- and it works for the Raptor 350 but the Warrior model ends in the 'X'. I mention this again because you may see several EXTRA letters at the end of the 'YFM350'.
Finally the third is MORE LETTERS! Fun huh. Anyone knows what they all mean feel free to post.
EDITED: Just found another model number YFM350S.
Discussion Starter #23 (Edited)
Raptor 350 Carburetor Information, Jets, Cleaning and Rebuild Information from Yamaha Owners and Service Manual
I could easily go into pages and pages of Carburetor how-tos and endless paragraphs. Carburetors are simple yet complex and they are affected by
many factors such as ambient temperature, altitude, fuel supply, condensation and a million other things. The best advice I can generally give
is to understand on a basic level how Carburetors work and get your Carburetor to FACTORY SPECS before attempting anything, that is IF your
RAPTOR IS COMPLETELY STOCK and the exhaust and intake have not been modified. Nothing sucks more than trying to get a Raptor running right only
to find someone messed up the Carburetor jet or float or 'ported' something in the carb to get more power and it may NEVER RUN right after. Get
a BASELINE FIRST of the carb running right THEN make changes and you can always revert BACK to FACTORY if you cannot get the carb to run right
after changing something.
I will break down the Carburetor into several sections;
1. Know how Carburetors operate in a basic level.
2. Know what your Raptor Carburetor is, how it works and the parts inside.
3. How to disassemble the Raptor and get to the carb to clean it and how to determine if you need to rebuild the carb when cleaning wont work.
Go on youtube and lookup ATV Carburetor videos. Theres alot out there but they all are basic and have similar things inside. Make sure you can
understand how fuel gets into the carb, how its metered into the carb that is, and what the float and and float bowl does, what each one of the
JETS INSIDE do and why there's different sizes.
SPECIAL NOTE: There is some confusion on what the internal jets and screws and parts inside the Carburetor are. Some call them 'jets' and some
call them 'pilots' and some call them 'jet needles' or just 'needles'. I CANNOT go into what means what just be aware you need to look at how
Yamaha calls them and use that as the reference. Mostly I MATCH the SIZE as each JET is different size.
- Raptor 350s have a BSR36 Carburetor made by Mikuni and sold to Yamaha.
- The Factory MAIN Jet is a #142.5.
- The Factory Pilot Jet is #22.5
- Pilot Fuel Screw Factory is Set 2.25 or 2 and 1/4 turns out from bottom
- Starter Jet #70
- Fuel Level in Bowl is 4-5MM above the float chamber mating surface (this matters if youre engine is being starved for fuel on acceleration)
- Float hight is 13mm (same reason as before)
Discussion Starter #24
Part Two, Part One is in the prior post above.
(I will repeat this again from the first post)
1. Covered in previous post
2. Covered in previous post
a. I have looked and there really isnt step by step instructions on how to rebuild a Raptor 350 carb or a video. There are some warrior steps and videos but I havent been able to find them. Also, even my carb rebuild kit for my raptor 350 didnt come with instructions. So yeah. Basically, I located each seperate item in my rebuild kit, once I opened the carb float bowl up, and replaced each part being VERY careful not to strip anything or break anything or force anything. Its a carb, not a prom date, dont force it to do something it doesnt want to do.
b. I used these carb rebuild guides with the first being the SAME carb in the Raptor 350s and its great.
http://www.off-road.com/atv/tech/atv-tech-basic-carburetor-cleanup-52101.html
This one is more of a general guide but has good information:
http://hubpages.com/games-hobbies/HowToCleanYourATVCarburetor
And this one is good too and has a video:
https://www.rockymountainatvmc.com/rm-rider-exchange/clean-carburetor-motorcycle-atv/
Do you have to uninstall the carb from your Raptor to clean or rebuild it. NO.
Most people loosen up the intake boots (the boot that connects the air filter to the carb, and the head intake boot (the boot that connects the carb to the head) and rotate the carb to the RIGHT (if you're sitting on the Raptor you would TILT the carb to the RIGHT making the bottom of the carb swing out from the bottom position toward your left side).
Discussion Starter #25
Carburetors General Jetting
Below is a GENERAL Information regarding JETTING that is NOT specific to the raptor 350 but a general guide.
1) Pilot jet/slow jet – Affects mixture from idle to 1/3 throttle opening. The pilot jet meters fuel to the “bottom end circuits”
2) Air screw – Meters air to pilot jet. It is usually located near the back or air box side of the carb. Turning in clockwise, will richen the pilot mixture. Turning out, counter clockwise, will lean out the pilot mixture. Average setting for most 2 strokes is 1 to 2 1/2 turns out. Refer to owner’s manual.
Note: If the adjustment screw is in the front of the carb, it is a fuel screw and not an air screw; it is adjusted the opposite of the air screw. Most 4-strokes are this way.
3) Jet needle aka Needle – Affects the mixture from 1/4 throttle to full throttle. The needle is in the leanest position when the clip is on the top, and richest on the bottom. The needle calibrates the full to the change in throttle valve (slide) opening. The further down the needle is, the later the main jet comes on and the leaner the mixture at that point.
4) Main Jet – This circuit affects the mixture from 1/2 throttle to full throttle. This is your full blast top end circuit. This circuit is most accurately tuned by checking the plug for the correct color, sort of mocha brown.
5) Float/Float valve/Float level – Your owner’s manual has the correct level and procedure for calibrating your bike. Here are some symptoms that would indicate the need for float adjustment.
A) If float level is too high, the float bowl overflows out the drain hoses, and fuel often blocks the air passages that allow the carb to de-pressurize. This causes a bog, or hiccup over large hits.
B) If float level is too low, the engine starves for fuel off idle, causing a “boooooowang” sound very similar to a pilot jet or air screw set too lean.
Jetting Guidelines; Eliminating the variables.
1) Never change more than one circuit at a time. You need this tool to tell you exactly which circuit is affecting performance and at what throttle opening.
2) Use fresh gas. Octane ratings diminish with time and the higher the octane the slower the burn and richer the mixture. The quality of today’s pump gas is decreasing. To compensate for the fuel, richer jets are required. Also note that fuel with ethanol (aka MTBE) also requires a slightly richer mixture.
3) Always start with a fresh air filter. Let a freshly oiled air filter dry at least 6 hours in advance so that the alcohol in the air filter can evaporate. Then match the carb to a motor that breathes properly. Otherwise, the engine will run slightly leaner when the clean air filter is installed.
4) When performing a plug check, use a good used spark plug. New plugs are white and are hard to read accurately for mixture checks. If you have to use a new plug be sure to put at least 15 to 20 hard minutes on it before attempting to get a reading.
5) Always check for clogged carb vent lines. Clogged lines will cause hard starting and bogging when the motor is hot. They can also cause erratic running that seems to mimic a mis-adjusted float, but worse. Performance will seem rich and acceleration will be sluggish off idle.
6) If you’re trying to track down a jetting problem, don’t change your premix oil brand or the ratio. The pre-mix ratio will determine how much fuel is available to be burned because the oil isn’t burned, and in terms of liquid volume, the oil takes up a portion of the liquid (oil + fuel). While the ratio will have a minimal impact when making small changes, remember that you’re trying to eliminate variables.
How to Jet
1) Mark your throttle housing and grip in 1/4 turn increments. Use a marker, razor blade, etc.
2) Now get the motor to operating temperature by riding around, away from the pits.
3) Once the motor is warm, ride in 2nd and 3rd gear from the low RPM to high RPM. This puts a good load on the motor and is an accurate test of performance.
* try to notice if the problem gets worse or better as the motor heats up.
4) Now try to locate the throttle opening at which the problem exists. See details just below.
Rich Jetting Symptoms and Solutions
A) Motor won’t idle and idle set screw is ineffective. Try leaning out the air screw by turning it counter clockwise a quarter turn at a time. If the air screw has no effect, install a leaner pilot jet and return the air screw to 1 turn out. Proper air screw settings are usually between 1 and 2 1/2 turns out. The correct pilot for your bike is one that allows instant off-idle throttle response, and allows the air screw to be effective between 1 and 2.5 turns out. If the problem still exists, check and clean the choke circuit and carb vent lines.
B) Motor stumbles off idle to 1/2 throttle, then cleans up. If everything in part A above is correct, check the needle. Stock position is usually in the middle, but check your owner’s manual to be sure. To lean out the needle, you need to raise the clip. If the needle is dropped all the way lean and problem still exists, try a leaner needle.
C. Motor will rev through the mid range then becomes gurgley (technical term) at full throttle and power is sluggish. This is a text book example of a rich main jet. This problem often occurs when an air filter becomes clogged and gets worse as the motor heats up. Choose a main jet with a smaller number and lean out the air fuel mixture one step at a time. If the problem still persists even though it’s improved a little, reinstall your original main jet and lean out the needle one position. Now fine tune the main jet with plug checks.
Plug checks are the key to fine tuning the main jet once the other circuits are set.
White Porcelain Chocolate Mocha Brown Black/Wet
Lean Perfect! Rich
Look for symmetrical burn patterns, smell for odors like burnt plastic, which is actually tranny fluid and would be indicative of a blown seal.
Lean Jetting Symptoms and Solutions
A) Motor hesitates off idle with a “Boooooooooowang” sound. This is a lean symptom and often occurs when a motor is cold. Try turning the air-fuel screw clockwise a quarter turn richer and check throttle response again until motor revs without hesitation. If the motor “hangs up” or doesn’t come right back down to idle, install a richer pilot, and reset air screw.
B) Motor knock knock knocks at idle when hot. Try solution A. If problem persists, perform a “leakdown pressure test” to check for ignition crank seal leakage.
C) Motor revs clean and crisp but runs really hot and lacks power. This symptom indicates a lean main jet and/or needle. Use a richer main jet and/or needle setting. This is the most common misconception about two stroke jetting: When a motor runs excessively hot and lacks power, it is on the verge of seizing. If you are on the trail and don’t have the right main jet, try raising the needle by lowering the clip. It won’t be exact but at least you won’t seize.
Note: To be certain that your problem is lean, pull on the choke and see if the problem gets better or worse. If better, your problem is a lean condition.
Discussion Starter #28
Yet another Jetting from joequad16 I think this is for Dual Raptor 660 Carbs but 660s simply have two 350 carbs. I like this one though.
Pilot Screw - Idle
Pilot Jet - Idle to 1/4 throttle
Needle Jet and Jet needle - 1/4 to 3/4 throttle
Main Jet - 3/4 to full throttle
1) Idle Screw
Allow the engine to reach operating temperature. turn to smooth idle. If unable to obtain smooth idle, go to Step 2, Pilot Screw
2) Pilot Screw
If unable to obtain smooth idle: turn the pilot screw in all the way GENTLY until it bottoms, then turn the pilot screw 1/4 turn at a time until achieving a smooth idle. The pilot screw should be correct between 1- 2.5 turns. If idle is between 1-2.5 turns, the jump to step 4, Main Jet. If idle is NOT smooth between 1-2.5 turns, then jump to step 3, Pilot/ Slow jet.
3) Pilot/Slow Jet
If idle is not smooth with pilot screw between 1-2.5 turns, then the pilot/slow jet needs to be changed. There are 2 choices. either A or B
A - If the pilot screw has been turned more then 2.5 turns to smooth the idle, then install a bigger Pilot.
B - If the pilot screw has been turned less the 1 turn to reach smooth idle, then install a smaller Pilot.
Note! A larger pilot jet will eliminate the popping sound that may occur when letting off the throttle.
A larger will improve cold-weather starts.
4) Main Jet
Start with the richest (largest numbered) main jet and test at full throttle. the engine should "stumble" at wide open throttle (If engine does not stumble, then the engine is not rich enough and a larger main jet should be installed). Once you have a rich "stumble", install the next smaller jet one size at a time until full throttle results in normal operation. Once main jet step is complete, go back to step 2, Pilot Screw, and perform pilot screw adjustments one last time.
Note! If quad runs faster at 3/4 throttle then at Full throttle, then the jets are lean and a larger jet must be installed.
Needle
If carburetor has an adjustable needle, this step CAN be performed. If you have a slight hesitation but NOT a hard stumble between 1/4 -3/4 throttle, then the needle is probably lean. Raise the needle by lowering the clip.
Reading Spark Plugs
Once the main jet is set correctly by dropping a main jet size after the "stumble", confirm the jetting of the engine by reading the spark plug. This works best in top gear in a slight uphill area. After running at full throttle, do the following at the same time: pull in the clutch and stop the engine, DO NOT LET THE ENGINE IDLE! Remove the spark plug amd examine the color. It should be a Light Tan. If it is white, then the engine is running lean and a bigger Main Jet must be installed. If the color is Black, then the engine is running rich and a smaller Main Jet must be installed.
Discussion Starter #29 (Edited)
Raptor 350 Reading Spark Plugs to determine Lean or Rich Mixture Adjustments
Reading your Spark Plugs tells you ALOT. Make sure to check your plug. You want that LIGHT TAN COLOR to DARK TAN. Note you need to follow the steps though to get the correct TIME to read the color (prior post).
Factory Spark Plug = NGK DR8EA
Factory Spark Plug Gap (ALWAYS CHECK) = 0.6mm - 0.7mm
Suggested Spark Plug = Iridium NGK DR8EIX
Suggested Spark Plug Gap (ALWAYS CHECK) = 0.6mm - 0.7mm
I run a NGK Iridium which part number DR8EIX.
Do what you want but I feel starts easier and revs faster. And I kind notice things like that if you cant tell. And it runs like $6 bucks :)
Last image is Spark Plug torque! DO NOT OVER TIGHTEN MR MUSCLES. DO NOT STRIP THE THREADS OUT.
Discussion Starter #30
Raptor 350 Engine and Transmission Oil Type and Weight
This could be another long discussion. Refer to the manual for details. Also, there is a prior post about oil and quantities. This post is specifically for oil type and weight (not capacity which the other post details).
Factory Recommended Oil Type: YamaLube 4
Factory Recommended Oil Weight: Depends on Operating Climate but most people use 10w-30 in colder climates like Midwest or Canada // and 20w-40 in hot climates such as latin america and US southwest.
You can use the chart below to determine what you want to use. You can use another oil than YamaLube, which I have, BUT IT MUST SAY ON THE BOTTLE 'WET CLUTCH APPROVED', OR 'JASO' or 'FOR MOTORCYCLE/ATV' (which the last one I am iffy on). If you use oil thats made for a regular car or truck YOU WILL HAVE PROBLEMS BECAUSE THE TRANSMISSION AND CLUTCH USE THE ENGINE OIL TOO.
Discussion Starter #31
Raptor 350 Front and Rear Tire and Wheel Sizes and Lug Pattern
Front Wheel Lug Pattern = 4 X 156
Factory Front Wheel Size = 10" tall
Factory Front Tire Size = AT21 X 7-10
Factory Front Tire Make/Model = Dunlop Tubeless KT851B
Front Wheel Lug Pattern = 4 X115
Factory Rear Wheel Size = 9" tall
Factory Rear Tire Size = AT20 X 10-9
Factory Rear Tire Make/Model = Dunlop Tubeless KT877A
Raptor 350s can accept wheels from these other ATVs (these are JUST the WHEELS and NOT THE TIRES, the wheel may fit the lugs but the tire may not fit the quad with the available room between the frame, plastics, etc.):
- 1987-2004 Yamaha Warrior 350s (remember to check tire sizes)
- 2004-2013 Yamaha Raptor 350s (yeah I know duh)
- 2001-2005 Yamaha Raptor 660s (05 last year of 660) (remember to check tire sizes)
- 2006-2015 Yamaha Raptor 700s (remember to check tire sizes)
Discussion Starter #32
Raptor 350 No Spark, No Start, Engine Cut-Out Related Items
Other than fuel delivery the other main problem I see for Raptor 350s is electrical problems. Either the battery is dead or dying or the CDI isnt working or the charging circuit isnt working or the ignition coil isnt working. Here are some things to start checking:
ATTACHED is the electrical diagram but its not huge here so you will have to get it from the SERVICE MANUAL which is in a sticky in the main 350 forum.
- Check main fuse. Make sure you are not looking at the SPARE fuse.
- Check that neutral safety switch is not ON.
- Check that clutch safety switch is not ON.
Check that REV LIMITER IS not triggered to be ON.
- Check battery voltage with Raptor OFF and Raptor ON. Off will test battery charge and ON will test CHARGING STATUS. I will get voltages and post them here once I find them.
- Check the -main switch- which is located near the headlight I believe. It should be a 2-pin connector, white. Touch the one probe to the brown wire terminal and the other to the red wire terminal. There should be continuity when the switch is in the on position and no continuity when the when the switch is in the off position.
- Check the -start switch-. Trace the wires from the left handlebar to down to the connectors. Disconnect the 6-pin connector. Set the multimeter to ohms of resistance. Touch the one probe to the black wire terminal and the other to the blue/black wire terminal. There should be continuity when the switch is pushed down and no continuity when the when the switch let off.
- Check the -kill switch-, you'll need to remove the front fender. Trace the wires from the left handlebar to down to the connectors. Disconnect the black two-pin connector with brown and red/black wires. Set the multimeter to ohms of resistance. Touch the one probe to the red/white wire terminal and the other to the red/black wire terminal. There should be continuity when the switch is in the off position and no continuity when the when the switch is in the run position.
- Check the -clutch switch-. Trace the wires that come out of the clutch switch and disconnect their two-pin connector. the clutch switch connectors from the clutch switch.
- Touch one meter probe to the black/yellow wire and the other to the black wire. There should be continuity when the is pulled in and no continuity when the when the lever is released.
Note from WillyKiller on Stator Problems
Unplugging the voltage regulator and rechecking for spark and if the bike will start, it is common problem on raptors for stators to cause a no start problem. Should your bike run with the vlotage regulator unplugged your stator is defective.
Everyone knows about the tell tale sign, if the raptor does not start and there is no spark, unplug the regulator rectifier and if it starts, then most likely you have a problem with the stator shorting to the ignition circuit.
Well what if you have good spark, good compression, fuel is okay and the raptor will not start, well I just went through one of these diagnostic sessions with a customer's raptor.
We unhooked the rectifier regualtor, tried a new CDI unit, checked for vacuum leaks, checked the timing, tried boosting with a extra battery, and once in a while it would start, maybe one in 25 attempts, BUT if you tow started it it would start everytime.
One of the disturbing symthoms it had was that when you turned the engine over to start it, occassionly it would fire through the exhaust pipe and stop the engine dead when turning over.
Well we installed a new stator assembly and now it starts perfectly, and the defective stator was only 2 months old.
CDI and Stator Testing
There are two coils, one is for charging your battery(charging coil) and one is for generating a pulse for your ignition coil(lighting coil). The cdi's main function is to control the point at which the spark is delivered to your spark plug, the cdi basically took the place of the old points systems. If it runs at all the cdi and the stator are good, as well as the coil.
There's 3 components in a warrior stator. I don't know the exact names of them but the main big round part is the charging coil. Then there's another coil attached to the charging coil, that's the trigger coil. Then there's one or two little coils that are on the outside of the flywheel. Some warriors have one and some have two of these little coils. I think they're called pulser coils, (or something like that), but don't quote me on that. If your warrior will start and charge the battery the charging coil is okay. If it won't start its's one of the other coils more than likely. When the CDI goes bad it won't run at all. When a stator goes bad it goes bad a little at a time until it won't run at all.
This is now a sticky.
Sharpraptor, thanks so much for your time and effort in putting this together. This has more info than even some of the service manuals I looked at. :beer:
Anyone know where to get OEM rubber like seat cover replacement and how to install? Im talking about the factory rubber-like seat cover that has staples on the bottom of the seat to secure the rubber like material. I like the factory seat cover material over aftermarket covers.
Have you looked into hondatoledoeast?
Discussion Starter #36
I checked out the link but it looked like a yamaha dealer webpage. I didnt know what i was looking for on there.
I wanted to find the OEM factory seat material (rubber?) with he dimples in it and also the procedure for restapling the new material to the underside of the seat plastic. wonder what tool does the staples and how the staples dont go all the way through the plastic
Discussion Starter #37
Thank you. I have just had, as stated before in the beginning post, several 350s and I feel they are WONDERFUL all-purpose quads, reliable, cheap parts, easy to work on, great styling and more. And after owning them I learned a few things or put together information from other people on the common service items.
Hi my name is Frank I bought two 2005 Raptor 350's for 3500$. I have had for two years only road at Oceano state dunes a handful of times literally. . Recently went to load them up and one sounded funny and had a hard time starting. When choke is on it runs, as soon as I turn choke off it dies unless I gas a lot and it still sounds like it's backfire almost ,but runs real rough. So I only took one. It has sat for two months since and I went to take it out and now this one does the same exact thing. I changed out the gas and spark plugs. Do I need to clean my carb or rebuild it??? Help please. I love my raptors! Great bikes
You're best to start your own thread.
WELCOME TO THE FORUM.
Alright so I'm on my first raptor 350...I've been around bikes my whole life have road yfz 450s all the 400s and so on.to me my 2011 raptor 350 has the best feel and ride out of all the bikes obviously ain't the fastest but mine stock was a bit faster then a stock 400ex and a stock ltz 400 Idk if it's supposed to be faster but it was...but I'm at the point where I'm use to the bike and want it to have a wider stance for better turning and also want to do everything I can to make it faster without big boring it..any suggestions? I could call the yamaha shop but I want answers from fellow raptor riders and what they think works best then I can have ideas of what to look into ya know ?
21 - 40 of 44 Posts
