1 - 16 of 16 Posts
I recently took out the spark arrestor from my 2011 raptor 350 and i going to put a k & n air filter and intake, what should i rejet to?
rejet
not at all. did it in less then 5 mins. just be careful not to strip any screws on the carb:) my mistake:(
lol but my quad runs fine:)
I have no idea how to rejet i have never even tried to mess with the carb, can u explain how u did it
Remove carb, get a small screwdriver, remove 4 screws at bottom of carb, take out jets, put new ones in, and install. 5 minute job.
Yess exactly what he said.
It is very easy you probably can go on youtube and look up how to videos
hey rappy'97 i've seen u alot on these forums alot and i wanted to see if your could explain rejeting to me because i have no idea how to do it
First thing you want to do is shut off the gas, remove the throttle cable, and choke cable, then remove the carb. Get a small phillips head screwdriver, and tap the screwdriver on the 4 little screws at the bottom of the carb. I take an adjustable wrench to turn it, and I can keep pressure on it all at the same time. Then, remove the pilot and main jets, and install the new ones. And out everything back together until you are happy with the jet sizes you chose.
1 - 16 of 16 Posts
