1 - 20 of 21 Posts
So I have a stock 01 raptor 660 with a full hmf exhaust I live at around 1600ft and am having trouble tuning the carbs I put 145 and 150 mikuni mains in and turned the fuel screw on the left carb 2 and a half turns and on the right turned 3 full turns but still had low end bog and out of nowhere doesn’t want to start at all HELP...
Both carbs need set the same, with the exception of the main jets.
The main in the right carb should always be one size larger than the left.
Is the airbox lid still on?
Discussion Starter #4
I also have a problem when I let off the throttle after giving it full throttle usually in 5th gear it will pop multiple times in the exhaust and sometimes kill the engine
You richened the jets... why? At your elevation you're marginally rich with stock mains.
Discussion Starter #7
It’s running now with a little bit of bog when giving it light throttle in 1st and second gear but still having the backfire issue on deceleration when it sometimes will kill the motor
Typically, backfire on decel implies too lean in the pilot (idle) circuit. The common fix is turning the fuel screws out (CCW) 1/4 or so turn each.
Discussion Starter #9
I turned out my pilot screw half a turn but still have the backfiring and today it killed the engine but it doesn’t always kill it :(
Could your pilot jets be plugging up? When and how were the carbs last cleaned?
Discussion Starter #12
I put a brand new carb on about a week or 2 ago so I don’t think the jets are clogged they were brand new
Uh oh... shoulda told us that in the beginning! If they're eBay cheapies you better take em off and just clean and re-install the originals.
Discussion Starter #14
My old one had a sticky float and needed the left side rebuilt so I figured I’d just get a new one but I’ll rebuild it and see how much of a difference it makes
Its all just cleaning... the hard parts never wear out.
Discussion Starter #16
I rebuilt the carb and now just waiting on intake boots hopefully it fixes it but I think I might have an air leak from the header pipe
Discussion Starter #17
One of the header studs was broken off and it looked like it’s going to be difficult to remove it
Is there anything sticking out or is it broke off flush?
It’s broken off flush to the head idk how I’m going to get it out
Couple options really. Google "screw extractor" and you will see several different styles. I prefer the type that come with a drill bit but thats simply my preference. Dont forget to get a t-handle for the extractor if you use that style
1 - 20 of 21 Posts
