The jet sizes were 144 and 146 with the needles on number 5 out of 6. I called dynojet and they said both needles need to be on number 4 and air fuel needs to be 3 turns out from bottom. Does this sound pretty close?
Yeah, both air screws should be set the same, and 2.5 to 3 turns counter clockwise.
Needles in 3rd or 4th, not 5th or 6.
146/148 mains sound good, and could go to 148/150(right main jet will always be one size higher than the left, all other carb settings will be the same on both carbs).
You also Need #25 or #27.5 pilot jets in both carbs, no way around it with open airbox.
#22.5 pilots are stock.
If you need the pilots
www.jetsrus.com
You can check/set the float heigth with the 3mm Clear tube method in the 660 Stickie section.
That also shows you how to trim float stops if you have high rpm fuel starvation issues.
