1 - 2 of 2 Posts
my raptor 660 has a problem where i turn the key and the neutral light dosent come on sometime and i have to mess with the stater soleniod and then turns off slowley and some times when i turn the kill switch to kill it turns on but when in on possition turns off or turns dimmer sometimes. also the starter butten when i press it the neutral light turns off or if i wait a bit the red light turns on when i press it like it should but still nothing. only works when i start it and the the start button works and starts it. and the light switch when i turn it to on or low or high it kills the engines if its running or just turns all the lights off the head light dont work aswell. i did nothing to it, it all worked a week ago its just been sitting please help
1st guess - you need to clean and tighten your battery cables at both ends.
2nd - fuse loose in the solenoid
3rd - key switch has corroded/dirty contacts
4th - harness plug loose at key switch
probably a few others
Reactions: thetruecarbon
1 - 2 of 2 Posts
