Hello All,
I took my carb apart to clean and now I forgot the order of the washers and white shim on the needles. The Raptor is bone stock, so I have the clip on the third notch (middle). Whats the next step Washer on top or bottom? Please help!
Thanks
Starting from the clip, on the bottom of the clip there is the white plastic spacer then a thin washer,, above the clip is the thicker washer then the spring, then the white retaining cap with the O-ring. Hope this helps.
Right on raron..............
