I just rebuilt the carbs and adjusted the valves and it will only start when I use starting fluid and won’t stay running and backfired and sputters. It seams like it’s not getting enough fuel but I can’t seam to figure it out does anyone have any idea ?
We need some history... Why did you rebuild the carbs? What did you use? How did you do it? When did it last run well? Have you made any mods since? Etc., etc.
I rebuilt them because it wasn’t running the best it was really poppy and sometimes loss of power. When I opened them up they were terrible so I bought a kit and replaced everything. I did not do any extra mods. But I did adjust the valves because I read it might be why its not running right and now I have a lot of compression almost too much for the starter.
Rule # 1 - only change one thing at a time! Since you rebuilt the carbs AND adjusted the valves it will be harder to figure out what has gone wrong...
What brand kit? Did you use the kit's jets and needles? Were the jets marked with the same numbers as those you removed? Did you completely disassemble the carbs and clean the body passages? Do you have the airbox lid intact OR is it holed or missing?
What did you use to determine you were at TDC compression stroke?
I don’t remember what brand it was it was just on amazon and could get here quick but I’m pretty sure they were the same. Completely disassembled them and I have the lid
