There is a crankcase breather, are you sure its not coming out of that?
Well i did my best to drain every thing and added 1 liter!
The hole i am talking about is just two cooling vins beneath the Oil gallery bolt, where you check the oil pressure!
Does any boby know what that hole is for?
It's a drain hole to the plug incase water gets in.
Oil coming out that hole is generally a leaky valvecover bolt, pull the tank and you should see it.
If it's the bolt's you can back them out and put a little sealer just below the head and run it back in.
You'll need a torque wrench too.
