I recently rebuilt my 2002 Raptor 660. Went with the Niche big bore kit and new OEM head. Everything from the jug up is brand new and all OEM except for the jug itself. After getting it all put back together, it seems I have crazy compression. When I go to start it, it'll turn over once, but stop. I've set the valves correctly, double checked my timing, bought a new starter, new cables to the starter, new starter relay. If I pull the plug out, it turns over just fine, but with the plug in, it doesn't seem to have enough power to turn it over more than one crank. I have the rocker arm clearance set to specs at 0.005" for intake and exhaust. Is there something I'm doing wrong?? I
