I have a 2002 raptor 660 recently it has turned off randomly and wouldn’t start and won’t start for a few days it’s getting spark and I can smell gas I also cleaned the carb. Its not even firing anymore this is the 2nd time it’s done this it stopped for a few days
Try using starting fluid - does it try to start? You still have a carb/fuel issue.
Lets clarify, It dies when you ride, or you shut it off and it won't start? Will it bump start?
As said, try some starting fluid.
Are you keeping it on a battery tender? You want to see about 13.5 volts. Try jumping from the wife's car.
Check the gas cap vent, air in but not out.
When did you last check your valve adjustment? Tight intake valves could cause hard starts.
