My raptor 660 won’t go past 70 km/hr and is hard on gas. The clutch isn’t slipping and it has nothing to do with the reverse limiter but it still seems to be an electrical issue. @QuadManiac help me please
It also randomly shuts off at high speeds and won’t turn back on for a bitMy raptor 660 won’t go past 70 km/hr and is hard on gas. The clutch isn’t slipping and it has nothing to do with the reverse limiter but it still seems to be an electrical issue. @QuadManiac help me please
You don't think out of spec valves could cause loss of power and when heated up cause it to want to die out? Not arguing or anything just curious.When it shuts offf, how quickly is it able to restart? Does it quit due loss of spark? If so try unplugging the rectifier/regulator and see if spark immediately returns - I'll then tell you what to do next.
It is not valve adjustment...
Everything is tuned properly. Did that firstIs it overheating? When was the last time you adjusted the valves. I'd start with a tune up, and just start ruling everything out.
My friend will try that soon and I’ll let you knowWhen it shuts offf, how quickly is it able to restart? Does it quit due loss of spark? If so try unplugging the rectifier/regulator and see if spark immediately returns - I'll then tell you what to do next.
Raptor's problem (and many other small engine's) is the opposite... as it wears valve clearance reduces until the point where, when it cools down, valves won't close fully and it won't start. When warm, clearance opens back up.(steel valve expands less than aluminum head) and it runs fine.You don't think out of spec valves could cause loss of power and when heated up cause it to want to die out? Not arguing or anything just curious.
It has a k and n air filter and a slip on fRaptor's problem (and many other small engine's) is the opposite... as it wears valve clearance reduces until the point where, when it cools down, valves won't close fully and it won't start. When warm, clearance opens back up.(steel valve expands less than aluminum head) and it runs fine.
Micheal, you should probably tell us your mods to exhaust and airbox and jet sizes being used.
It has a slip on fmf pipe. A k&n air filter. And my friend tried those things. Didn’t do much. It has started up quickly a few times it shit off but usually takes a bitRaptor's problem (and many other small engine's) is the opposite... as it wears valve clearance reduces until the point where, when it cools down, valves won't close fully and it won't start. When warm, clearance opens back up.(steel valve expands less than aluminum head) and it runs fine.
I also don’t know the jet sizes but in 90% sure they are stockIt has a k and n air filter and a slip on f
it doesn’t fail to run it literally turns off. Like fully off. No power at all no lights no nothingHave you checked for spark when it fails to run?
Thanks - this is new and important information! This likely means that power to the CDI (and everything else) is being interrupted. The most likely place for this to happen is at the key switch.it doesn’t fail to run it literally turns off. Like fully off. No power at all no lights no nothing
I can’t exactly do that lol. It has a switch not a key fob I don’t think the key fob is even connected to anything. But I do know the switch was just required and done properly so it shouldn’t be an issue.Thanks - this is new and important information! This likely means that power to the CDI (and everything else) is being interrupted. The most likely place for this to happen is at the key switch.
If you have a Volt meter and know how to use it you might measure DC voltage at the red wire going into the key switch and the brown wire leaving the key switch (with key on, and just after it has stopped running)... both wires should have around 12V on them... if the red does but brown doesn't the key switch is bad, dirty, or has some other malady.
Try aggressively turning the key ON/OFF/ON/OFF/ON/OFF a bunch of times to try to clean the contacts... you can also spray electrical contact cleaner into the key hole, or even WD-40 and then exercise it as described above.
Let us know what happens.
I contend it (or someyhing related) was NOT done properly... If you can't deal with using a Volt meter you better find a freind who can!I can’t exactly do that lol. It has a switch not a key fob I don’t think the key fob is even connected to anything. But I do know the switch was just required and done properly so it shouldn’t be an issue.
No he’s already checked all that. He required it himself because it was on there horriblyI contend it (or someyhing related) was NOT done properly... If you can't deal with using a Volt meter you better find a freind who can!
Who is 'he'? And how do you know he has a clue about what he's doing... as I can assure you that WE do!No he’s already checked all that. He required it himself because it was on there horribly
Its not CDI or stator dammit - they have nothing to do with loss of lights. If your friend truly had any electrical knowledge he would understand this.it doesn’t fail to run it literally turns off. Like fully off. No power at all no lights no nothing
