1 - 20 of 245 Posts
I purchased a used raptor privately from a guy who said it has not been used for 2/3 years. It started up on the first day and the exhaust was 'popping' like gun shots , when pressing the throttle and in gear it was just idling along and not responding to the throttle.
So - i tore it apart, cleaned the carbs ( carbs was clean anyway when opened and looked spotless , cleaned all the jets but left the fuel and air mixture screws how they was.
put the carb etc back together with a new battery and now when i try and start the bike, all i can hear is a clicking sound from the solenoid.
I have ordered a new solenoid, new oil filter, new oil, will put in fresh fuel and i will jump start with a car battery when all these are fitted.
new battery dont seem very strong and dont have a voltage tester , but i can jump start it with a car.
Should the above solutions fix this issue? or is there a different issue here?
any help would be highly appreciated
Definitely need to get a volt meter and see what the battery is reading.
Reactions: jsanders347
What year is it? Is it stock? Kill us with details.
Sent from my SM-G975U using Tapatalk
Discussion Starter #4
hi,
So i need some light shed on this topic. I purchased it as a 2006 yamaha raptor 660r special edition. Now i know people say 660 is to 2005 only, but how can mine be 2006?
The quads log book or title is stated as a 2006 yamaha raptor 660 even when checked online through the government website. Did yamaha make a few special edition 660's in 2006?
Ok so its got a powercore bomb 4 exhaust system and a k&n air filter. Its all stock other than that.
First day it started, was ideling and the exhaust was just popping like gun shots which did not sound right. cleaned carbs, replaced battery and then its solenoid is clicking.
It's possible Yamaha made a 660 in late '05 and called it a '06. If so it is a rare bike.
When cleaning the carbs it's necessary to run a fine copper (speaker) wire thru all orifices in the carb bodies.
Your starting issue is most likely a low battery, indicated by the solenoid clicking. Even a new battery will require a few days on a low amp trickle/float charger.
I can't help you with jetting. Do you know what jets are in now?
WELCOME TO THE FORUM.
Discussion Starter #6
Hi thanks for the reply.
So i jump started it today with the car and it turns over and starts very rough. But as soon as i let go off the start button it cuts out. I put fresh fuel in and also checks the fuel flow and its all fine.
I ordered a solenoid for a 660r raptor and the one they sent dont fit.
Im just going to take it to the garage on THursday and let them break my BANK as I just cant get it going :/
Discussion Starter #7
Hi, so i took the quad to the garage and they said that its something todo with the top end and will need a rebuild? Whats my options? is it hard to do this yourself or rather let them do it?
Whoa!! They need to pinpoint it more.
Ask if it has compression.
Ask if the timing and chain adjustment are good.
Ask if the valves and adjustment are good.
Any of these being bad could cause no start, but not necessary need a rebuild. They need to give you a reason "why" it needs a rebuild. A top end rebuild may cost at a shop may exceed the value of the bike. What was their total price? Was this a free estimate? You might get a second opinion.
If you have basic mechanic skills you can do a top end rebuild yourself. a "CP" 11:1 piston, cylinder bored, timing chain and gaskets should be under $500 USD. But a valve adjustment could be done the first time in a evening following the manual.
Discussion Starter #9
Yeah thats true but as soon as they jump started it and heard the clanking sound from the top part of the engine they shut it off and said they cant do anything unless it messes it up more.
They did not open the engine, and when i asked how much it'll cost to do a rebuild he said around £1000+
not sure about compression, value adjustment etc as they did not check it.
I have good mechanical skills with cars and bikes etc and could do it myself if i know what to buy for the bike and how to take it apart etc.
Could you please make a list of what ill need to test everything? valves , compression etc?? would be highly appreciated as this is my first quad bike
Ask if they have a "bore scope", this allows locking in the motor thru the spark plug hole. You need a firm price for repairs, not we'll open it and charge more money.
Real loud clanking could be bent or broken valves and prolly wouldn't run.
Or valve noise could need valve adjustment and/or a timing chain is loose.
A bad lower crank bearing could make a lot of noise.
I would say check the timing chain, then pull the head off and that should reveal what's wrong.
Approximate US prices, and in USD;
CP 11:1 piston, $225. There are cheaper but don't have the quality.
Factory Yamaha head and base gasket, $75.
Timing chain, $25-$30.
Bore and hone cylinder, $75-$100.
If the crank is bad, look for a new motor as all the bearings will have metal chips in them.
Reactions: morphrider
Discussion Starter #11
Thanks,
So the bikes now in my garage as thye said take it due to lack of space, they are a two wheel motorcyle Specialist. So as the noise is coming from the top of the engine, ill take the head off first?
So first steps wuld be to check timing chain? how do I check this? there are videos on youtube that should it on the raptor 700 engine, ( are they similar ?)
Next would be to take the top head off and see if anything is broken? or shall i take the valve case off and see if they are fine?
Also the parts you listed , i found a CP piston set on here http://jsdmachineworks.com/cp-pistons-01-05-yamaha-raptor-660-big-bore-piston-4mm-stroker/ is this the correct one?
It would also be much help if you can send me links to the correct parts as there are many websites etc and im not sure which ones sell genuine ones.
I will tear the top end apart this weekend, i will also try and start the bike and video record to show you what the sound is?
First let me say I'm not real familiar with the 660, but I'm going by general motor knowledge. First, you should message Morphrider, with a email address, as he may have a link for a free service manual.
You remove the timing chain center bolt and spring. Then remove the adjuster and count the teeth to see how far the adjuster is extended as a indicator of chain stretch. Then, carefully take the valve cover off, it may be glued on. Then check the timing marks on the crank and alignment with the cam. All this is in the manual and you can continue with it. I would be typing all day only to quote the manual. Then if you get stuck, you can ask individual questions for help.
The piston in your link is not correct as you don't have a stroker. BUT, you should wait to order a piston as your cylinder may need machining requiring a oversize piston. Also I saw a option for a DLC wrist pin. You don't one.
Discussion Starter #13
Hi thanks,
So if you don't mind could you make me a list of everything i need for a engine rebuild and i will attempt to do it myself?
Any compression testing machines etc also required or just parts?
Would be much appreciated
My posts 10 and 12 answer your questions. Except you don't need a compression gauge or a bore scope. That was if the shop was gonna do a blanket estimate without knowing what's wrong. My price estimates may be lower for a 660 as I'm more familiar with 700 prices.
Did you message Morphrider for a manual??
Discussion Starter #15
Ok thank you ill take a look and see if i can order them parts. I have been watching michael sabo on youtube where he takes apart his raptor 700 motor and rebuilds it all. Would this be the same for the 660?
I found the manual on a post my morphirider and downloaded it, its amazing has everything so i did not need to message him for it.
You shouldn't order a piston till you know what size you need. The cylinder most likely will need to be bored our, requiring the next size or two piston.
Discussion Starter #17
How do i find out what size mine is? what do you mean the cylinder needs to be bored out?
If this is not a simple rebuild of taking old parts out and fitting new engine parts, do you think its best if i just take it to a mechanic?
Have no issue if its a case of replacing parts with no further things etc...
First you need to find out what's wrong. Start by checking timing marks, follow your manual. Take the valve cover and head off.
Second determine what parts need replaced. Normal top end rebuild includes timing chain, gaskets, bore the cylinder and new piston. You would take the cylinder to a machinist who would bore it and determine the size for the piston. This is in your manual.
Check the head, in the manual.
You should read the rebuild procedure in the manual a few times to familiarize yourself with how it's done. It may sound hard but only takes basic mechanical skills and the manual.
1 - 20 of 245 Posts
