my 2001 660 raptor sat for a year because it needed a starter clutch and after I put one in I filled it with oil and it stayed the same for a while so I took it out and when I was ridding it its started to die out so when I look at the oil dip stick there was no oil and there was no leaks on the side where the fly wheel is and when I retimed it and put new oil in it, it doesn't want to start and I cant figure out why.
We need more information to help you.
Have you checked to see if it has oil in it NOW?
Have you checked for spark?
Does it have enough fuel in the tank?
Do any of the lights work?
Does the reverse light work when in reverse?
Please be verbose and tell us what the symptoms are in detail! It doesn't want to start just isn't enough to even start a conversation.
I have a 2005 raptor 660 and it turns over it just doesn't start but ive changed the sparkplug i checked the oil the oil filter i sprayed starter fluid in carb is that enough detail i need help please
Welcome to the forum!
1) This thread was 13 years old - Start your own thread please.
2) check for spark
3) report back in new thread
