First like to say hi.. just bought my first raptor and im new to the forums.
I did alot of research and still am dumb founded by this.
The starter turns over slow as if there is too much compression to start. Also the battery cable would get real hot. I did get it to jump start off my truck after idleing for a min or two it died tried to jump start again and it went back to the slow cranking .
I have just replaced the battery cable to the relay with a more heavy duty one as well as bought a brand new grizzly 660 300cca battery. I put it in it fired right up. Ten one min of idle it died again. Trued to restart and it was slow cranking like there is too much compression.. please help
2002 raptor 660 with 686 kit.
I was told that the starter itself may just be too weak. But don't know what else to check.. also when it does fire up if I hit the gas it will pop and backfire slightly ... but also not warmed up obviously
