41 - 60 of 67 Posts
Clutch problems
Hello i am new to this forum. I was wondering if anyone could help me out with my raptor 700. When the quad is running it shifts fine and clutch ingages just fine when i shut it off the quad will roll in nuetral like it should but when i stick it in gear and pull clutch in it wont let me push it anymore. Any Suggestions? any help is good help thank you
lot of great information here thanks. I have a question for ya though. I am having a high comp piston, HOT Cam stage 3, FCI intake, barker duels, power commander, and some port and polish work done to my 08' raptor 700. I am having all this done while I am here in Iraq for when I get home. Will I need to change out my radiator due to cooling problems or will the factory one suffice?
Yeah man this site is an excellent resource for us rappy guys! And there is a lot of great guys on here that just like to BS so that makes it a fun pastime.
OK I saw this on an LT-R450 forum and decided to try to make one on here since its a good idea since people dont like to search anymore and i thought you guys would find it handy. This is a gigantic list of the FAQs that most people ask and talk about for the Raptor 700. Please feel free to pm me and tell me if i missed ANYTHING. Hope You like it :thumbsup:
Id also like to keep this on the 1st or 2nd page so that people who are newer to the forum can easily find threads that they need. Sticky maybe?
I'm new to the forum...this is a huge help! thx
i have a an 07 raptor 700 and im having a starting issue. i lost power and it shut down. it started back up and i rode another 1/4 mile and it shutdown again. it fired up 1 more time and istantly shut down. now the starter solenoid is just making a humming noise what could be my issue
Is the 700 manual up anywhere else? Those two links don't work "file not found"
not sure if i have the same problem, ive got an 07 raptor 700 pretty much stock have a stage 4 trinity kit which includes K&N,intake,full pipe and EFI was told by my mechanic that i could run av-gas and it would make my bike better due to low lead and no dirty blends like we get from pump gas. so i did,and for about 2 hours my bike ran fantastic better then ever and then all heck broke loose now it wont idle runs rough, and bogs out, smokes, from 0-mid throttle but wide open runs fine! whats wrong and did the av-gas do it! or is it the tps how can i find out without spending 118.00 dollars for a new tps
What does your spark look like? Put a new plug in and see if that helps. Av-gas is just that, for airplanes. Can be found in two octain levels depending what your air port has. 100LL and 110LL. Formulated to work at 2-3000 ft in your area, as well as a constant RPM. That means you "should" ride (fly) 2-3000 ft above your airport and use a set throttle position. Can you use it in motorcycles? Of course, I've done it for at least 20+ years, and it's been used before me!! In 2 strokes and 4 strokes. But I've only used it for the octain, and mixed it 00/00% with pump gas to get what ran best in my bikes. I try not to go over 50/50%. If I need more then I use race fuel, with or with out pump gas. Race fuel can be run straight or mixed with pump gas. Did you notice I used the words "fuel" and "gas"? They are not the same.
Sorry, I got carried away. I dont think the av-gas caused a problem unless the lead pluged your injector (long shot). But your symptons would be reversed! You may have some other problem not related to av-gas. Try a new spark plug and pump gas. Run more then 1 lap around the house. May clean out by itself.
Want to change the color of my raptor...
Hey there everyone..New to this forum thingy. So bare with me. I have a 2012 Raptor 700 that is blue...I would like to change it to pink.Also just got a bunch of new riding gear for Christmas that is black and pink..Is that possible? :):)Merry Christmas Everyone!!!
Got the other version of this page, but forgot to unstick this one. Thanks for pointing it out.
A software "update" broke all of the links without recourse to resolve them and as such this page is no longer useful.
Are they somewhere else?
41 - 60 of 67 Posts
