Does anyone know what setting it should be on? It randomly started popping a bit while I was riding.
No it’s not stock, it has DMC comp 4 exhaust, K&N air filter, has the big 3. It has JD fuel programmer and when I was riding it popped a bit. I need to know what’s the right setting to set it up as.Raptor 700 is fuel injection, not carb, so no jets. Fuel controller is needed. Is the machine stock?
It was popping at mid, also thank you so much. I could’ve used this info before I messed up the settings.Where did it pop at low,mid,high? Add fuel were it was popping at.
