Hi, can you guys recommend a carb rebuild kit for an '02 Raptor 80? I see that Shindy makes one (for sale on Ebay) and I see a few others. I've been having a time with the carb on this bike. The bike stalls out at idle, the carb will flood and "overflow" if I leave the petcock on. I've had it in the shop and the carb was pulled and cleaned but it only fixed it for a little while. I'm using fresh 92 gas with stabil and have a new fuel filter inline. thanks for any and all help!
I used the Shindy kit and it worked just fine. After you strip the carb down, spend a lot of time on the passageways as a grain of sand can cause mountains of problems!
I used a kit from moose industries on my 50 and it worked great. I was having issues with my carb even after the rebuild & it turned out to be an incorrectly routed throttle cable. Just something you may want to look at.
Discussion Starter #4
Thanks so much guys!
kawadank, how was your throttle cable routed? Did it have a bad bend and the top of the carb?
