1 - 2 of 2 Posts
Same problem as last spring. Forgot to drain the fuel out of carb and now won't run off full choke. When you guys talk about removing fuel lines and loosening the clamps to turn the carb to access the bowl screws, which way do you rotate the carb? Thanks.
Check the thread at the top of the forum... I go through how to clean the carb and upgrade the pilot jet which make the quad run a lot better.
1 - 2 of 2 Posts
