1 - 11 of 11 Posts
Dose anyone know if a raptor 700 axle will banshee? My friend has a banshee bent his axle today and I have my stock axle laying around and I was wondering if it will work in his banshee.
OK I got it laying around so I told him we can try it and worse comes the worse he has to get a g force one. I'm just hoping to get some of this stuff out of the garage.
I know the banshee axles would work in a raptor 660. Don't know about the other way around and with the 700's. The offset might be slightly different but would be worth a try.
which offset? I was looking at a website with the durablue axle and it said it fit the 660,700 and banshee. so I don't know if they figured something out so it would fit all three and a few others.
Yes, banshee axle is about an inch longer. Don't be surprised if the offset is a bit off from one to the other though, an extra 5/8" on one side if I remember right.
OK, I know that wouldn't be good on the chain side but you could space out the brake caliper to fit.
I'm actually looking back through my subscribed threads trying to find the one I saw about using an complete Banshee swingarm/axle on a Raptor. If I remember correctly it was longer and wider (like you said) and I have one lying around but I can;t find it and I'm on page 12 so far. LOL
The offset won't affect the spacing of the sprocket or brake hub because you flip the axle around, you just end up with one side slightly longer than the other.
Not sure about putting the shee arm on it, though I guess if it's longer it would be worth investigating.
1 - 11 of 11 Posts
