What type of dash? OEM or aftermarket?
If it's oem or aftermarket plastic you need to have the two tabs on the stem mounts and the rubber fittings that fit over them. Then hook the tabs on the dash into the rubber fittings and you're all set.
If it's aftermarket bolt-on type you need to remove the oem dash and hardware. Take the dash off, remove the 4 bolts holding the clamps for the bars and then use these same bolts to mount the new dash onto the top of the stem where the old clamps came off. Tighten these four incrementally and in a cris-cross pattern to keep everything level and straight. Make sure you properly position your bars by both centering them in the stem/clamp and forward/backward rotation in the clamp before you get the 4 clamp bolts too tight.
If it's a trail-tech "dash" then mount the bracket through the stem clamp bolts in either the front (away from you as you ride) or back (before the handlebars and towards you as you ride). I believe there are also ways to mount them directly to the bars. If that's your aim then I'd check around the 700 forum, there are a number of riders buying the new vapor and mounting them there.
