SIC said:
when u spray on the WD40 or the PAM does u just spray the bike, or wipe it down with it?
While the bike is still wet from rinsing, lightly coat entire bike with wd40 this includes motor casing, hoses, frame , exhaust, EVERYTHING. Then let it air dry. The next day or the next time you go in your garage if there is any excess wd40 spray that you can see then wipe it of, do not wipe hard just gently wipe, Like you would wipe your ass.The bike should shine like new. The next time you go riding you will notice that all you have to do is rinse the bike with a normal garden hose .No pressure washer needed for this process. when rinsed to your satisfaction, reapply WD40.
(this is what I do . I am not to be held liable for anyones own stupidity,for spraying brakes with WD40 , as when I say spray everything . I mean all but brakes.
