i am looking at buying a 02 660 but i think the one way is out b/c when i push the button u can just hear the starter spin over but it will not grab the mag i am shure that u guys have heard all about this b4 but i just want to know it that sounds like what it is. and if it is then i was wondering what some good ones are for the price i dont want to spend that much money thanks alot
phucker said:
yes that sounds like the one way starter bearing. only get the l&a one way, the oem are junk. it will cost about 200 bucks or so. you can get it from www.rspconcepts.com
More often then not you'll also need the 50-60 dollar OEM 52 tooth starter gear. By the time you add in gaskets, better bolts for the one-way, loctite, and sometimes an oil change you're looking at around 300 bucks in parts.
Why the bearings go bad can be found here:
http://www.raptortranny.com/oem-one-way.php
Nice little write up with pictures, short and to the point.
