1 - 2 of 2 Posts
I have a 2001 raptor, I dont know what the problem is but its stuck in reverse. It does not matter what gear I shift it into, it will only travel in reverse. I looked at the reverse cable and it seems to be releasing all the way. Any sugestions, I am wondering if one of the gears are broke. thanks
Hmmmm... I would disconect the revearse all together. Then mess around with it where it connects the engine block and see what happens then. If its disengauging then you need to take your clutch plate off and look and see if you have any dirt or grim in there causing the gearing to jam an not shift back.
1 - 2 of 2 Posts
