sometimes when i rev it it kinda high and then i brake it will turn off on me. it starts back up just fine just wondering if this is somethin i should b worried about.
You're probably dropping your rpms too low for the bike to stay on in gear. Engage the clutch if your speed is anything close to a stop, especially if you're in a higher gear. Also, make sure your idle speed in not set too low.
i put the clutch in and it still does that. how do i check my idle? and how do i know if its low or high?
I adjust mine by ear. However, the correct way is to use a tach and set it to specs. The adjuster is behind your fuel shut off. Turning it clockwise will increase your idle, counterclockwise will decrease it.
