Discussion Starter #2
Can someone please assist in have attached a photo above on the part that I would like to identify. Found it stuck wedged between the gears after removing the clutch. Circlip must have come off that is supposed to keep it in place and it ended up stuck in gears. Don't know what it is called
I couldnt tell you the exact name of it, but its basically a trigger wheel for the crank position sensor. It goes on the clutch side of the output shaft of the transmission
Reluctor wheel for the speed sensor / limiter. When you get a new one, grind every other tooth off. That way it thinks your going half as fast as you really are.
You can see the sensor in the case that reads it. I don't know how it would behave if you just left it out.
