By pass neutral swich
New oem starter relay
New battery but using car battery to make sure she has all the volts she need
No clutch swich on clutch lever
Only light is the temp light
You posted 3 times. Please delete 2 of them to prevent confusion.
WELCOME TO THE FORUM.
Not really sure what ur asking for or even whats going on.
1. Does the starter crank but no fire?
2. Have you confirmed that you correctly did the neutral bypass and the PB delete?
3. Will the starter crank with just the bike battery? If not fix that problem first, you shouldnt need a car battery if everything is right and the use of the car battery could lead to further damage.
Help us help you!
Sent from my Pixel XL using Tapatalk
