What is going to happen if I use 5w-40oil in the raptor700
lilyoung099 · Registered Joined 2 mo ago · 1 Posts Discussion Starter · #1 · 2 mo ago Only show this user What is going to happen if I use 5w-40oil in the raptor700
D DFWJosh · Registered Joined 3 mo ago · 14 Posts #2 · 1 mo ago Only show this user short term, nothing. long term, probably wear out the clutch faster than normal. reg oil is ok short term or if you just need to add a little if you're low; I would not run it long though.
t web2007 · Premium Member Joined Oct 22, 2009 · 3,271 Posts #3 · 1 mo ago Only show this user lilyoung099 said: What is going to happen if I use 5w-40oil in the raptor700 Click to expand... No harm in 5-40, so long as it’s a wet clutch compatible oil.
