I am going on a big new years ride soon and want to know if this is ok or if i need to fix it asap... i have a little play when i push the quad from side to side and wanted to know if this normal... its hardly anything but i dont want to have more crap go wrong with it...
set it up on a block and find where the play is comming from. i've had axle bearings seize while crossing train tracks and they killed the motor :eek: its could b the swingarm bearing which are not as bad
ok well i did that and my whole axle moves and it looks like the inside of the swing arm is the culprit...
Axle bearings are easy if you can get your axle out. Remember don't force it get a bigger hammer. :wow: anyway just punch them out of the carrier and gently tap the new ones in. then spend the next hour reassembling the quad.
Personally i couldnt get my swinger bolt out when i did it, but i didn't really have too. I wanted to replace them just cause i was already tearing into it. I gave up after a lot of wacking. lol
