1 - 2 of 2 Posts
Does anyone know if I can use a hardend hex head bolt or any other type to hold the rear rotor on to the hub instead of those [email protected]#king allen bolts ??? I just had them out last year and they were so tight again I had to use an air hammer to "BURP" then loose, then work them out with the allen wrench . Only used a little bit of blue loctite when assembled last,,,
I believe you are stuck using those bolts since they do have a shoulder on them to center the rotor..............:D
1 - 2 of 2 Posts
