1 - 2 of 2 Posts
On my sons 07 Raptor 250, the rear caliper bracket, the part that attaches to the swingarm, is loose and rattling around. It does not bolt onto the swingarm so how do you tighten it?
you dont they all rattle they are suppose to be loose . there is a snap ring that holds it on behind your brake rotor. it needs to move when your adjust your chain. loosen the 4 bilts on the rear swing so you can adjust chain and you will see how it moves.
1 - 2 of 2 Posts
